my lg esteem is slowing down dramtically.. i have it overclocked at 2.0 ghz with the gingersteem rom... it use to be fast but slowed down.. can anyone help
does lowering it speed it up?u might wanna lower it down 1708 and 368
oh ok so like 1 day i can run 2.0 then the next i have to give it a rest?no but ur phone needs a rest running 2. every day may cause ur phone to acted up I had that problem now I'm running 1612 /368 and still moving fast
well i do like a phone with no lag or wait time just trying to get as much as i can out of my moneyI may be at the other end of the spectrum on this, but I don't really see the need to go above 1.0/1.2 Ghz. Do you really need 2.0 Ghz to web browse, make a phone call or send a text message? I guess if you play a lot of games with intense graphics then I could see it, but it makes the battery drain faster, and it does stress the phone to run extreme OC and will probably shorten the lifespan of the phone.
Well I have you tried using cachemate? I use it when my phone gets a little slow. clears up all the cache and improves the speed.
