I keep getting this warning. I don't have a lot of apps. I have deleted all text messages. What can possibly be causing this?
Gmail's don't download when I have this warning.
by going into "internet" and clicking "clear cache" or is there some general clear cache option I'm missing in there?
thanks.
download .. quick systems info
then tell use what you see for your memory information.
can you please give us the mem of all 3:
Internal storage
system storage
cache storage
it does look like you have used a lot of the storage. you may not have a lot of apps, but they maybe very big apps. I bet your hero is very laggy.
options:
1. remove apps till you get more memory back.. you should be above 50mb free; if you want better performance. The more the better.
if you are rooted and running custom ROMs.......
2. for android 2.1 or lower: use Apps2sd and move some of your apps to your SDcard.
3. for android 2.2 or higher: use the internal feature to move apps to SDcard
4. use the Firerat Mod and combine all the LOST free memory into usable memory. This can be combined with options 2 or 3 for even more memory. (not for the non-tech)
Set up your Quick System Info.app. to clear all caches with that seperate icon on your main screen,that way you can clear all caches at once and anytime you want.If that doesn't help then back up everything and do a full reset.
com.htc.socialnetwork.... takes up 12.24mb
what is that?
