Root Phone storage won't mount as hard drive...
dubsides
Baseband - 2.15.00.07.28
Kernel 2.6.32 Hydra ssuv
Frankenrom B5
Riptide Clearfroyo (Evo) theme
In windows(7-64bit-ultimate) I have 2 disk drive entries in device manager for android phone, but only one shows volume information (for SD Card), the other shows "no media". (I also tried this on a different windows computer with the same result)
In linux mint (& ubuntu), 2 android phone drives show under "computer" but only one mounts (SD Card).
Obviously the SD Card pops up fine, but I can't get the phone storage to mount as a drive. I can see all the phone storage under /emmc in my file manager on the phone, and it shows up in the settings menu. I do notice that when I mount as a disk drive only the SD Card gets greyed out, not the phone storage...
I've tried using USB debugging, mounting through unrevoked, etc... no luck...
I haven't been able to get rom manager to fix permissions for B5, is that a possible thing to look into???
Anyone have a similar installation that works fine?
Mods feel free to move this under ROMS or anywhere else you want...
Thank you!!!
its a problem with having the evo theme installed. i am in the exact same situation, i believe adrynalyne has a fix for it and will realease it in the b6 of frankenROM which will hopefully be tonight if he has time to finish it. see the evo port test thread to keep up with it.
Thanks! I was wondering if it was something like that must have accidentally skipped that page of the thread... whoops!
