phone storage
  • Start date Start date
You may be able to move some apps to the sd card on your device. Either through the built in application manager or using an app such as App2SD.
If you have a lot of applications installed it may be time to uninstall any you don't use.
Also, if you have a lot of pictures or videos, you may want to transfer those to a pc and get them off your device, or use a cloud service such as dropbox which has an app for your device.
