Root Phone stuck at boot
tictacs5
This is my first post on the forum, so my apologies if this is the wrong section or anything like that.
I was able to successfully root my Samsung Galaxy Reverb with no issues. I didn't install any custom roms or anything like that, but I did try to change the screen resolution because I read thats one of the many things you can do with a rooted device.
Me being the ignorant fool I am, didn't research the topic at all, set the new screen resolution, restarted the phone, and watched in dismay as it got stuck at the SAMSUNG logo, as it is still stuck now. I did boot into recovery mode and try wiping the cache and tried a factory reset, neither of which worked.
Can anyone help me with this noobish mistake? Or is my phone useless now?
You're going to have to flash CWM recovery. Then flash a rom( the Super Stock ICS is good). Since you didn't back up your phone before hand, you will loose all your applications and etc. Good luck
Thank you. Are there any tutorials on how to use CWM catered to the Reverb, or will any old tutorial on Youtube and such work?
