Root Phone stuck on HTC splash screen, no idea what to do.
Fedora123
Idon't know much about how to install a rom. I Installed CM7 using a guide but the rom ended up being buggy and kept crashing constantly.
I decided to try and restore the original factory android 2.2 rom, using "PantsROM", as it was the only one that I could find.
I did it through Clockwork mod, by choosing to install a rom from SD.
Now my phone is stuck on the HTC splash screen, and I have no idea what to do. Is there anyway to fix this?
Edit: I managed to get the rom working, but every time i try to download an app from the app store, the phone resets.
Clockwork mod doesn't seem to be working either, and when I go into the clockwork recovery mod, it says that there is an error mounting the sd card.
My HTC-G2 gets stuck in white screen with HTC logo on it. My phone is in S-OFF mode.
clockmode recovery is 5.0.xx version and gives below errors
E: Can't mount /cache/recovery/command
E: Can't mount /cache/recovery/log
E: Can't open /cache/recovery/log
E: Can't mount /cache/recovery/last_log
E: Can't open /cache/recovery/last_log
