Help Phone Stuck on Logo Need HardWare reset
Hello, so I do know that there alot of other threads which talks about my issue but honestly I could'nt find what i was looking for,
I recently rooted my phone and as I was messing around with it, I wanted to delete some preinstalled apps to make my phone's memory free up some space, but then stupidly I let my little cousin play with my phone. I am not sure what exactly he has done but when I got it back It came up with around 20 force close messages of applications such as android it self.
Then I plugged my sd into my pc then realised there was a folder named 'app' inside the folder 'app' and that folder had all the other preinstalled apps in it...
So I know that he has moved preinstalled apps into the apps in sd card.
So, whenever i try to turn it on it just turns back off and reboots but never actually turns on.
I would like to know if you can reset or get back my data without having to use the actual turned on phone.
(yes I am very stupid, and a newbie on these kind of things :( )
