Help Phone Switch Off Then Battery Drain
i was just on my phone sending a message then my phone just shutdown with 44% battery left. then i took out the battery and put it back in then switched off the phone, my battery was then on 22%
just wanted to know if this has happened to others, and if not how can i fix it
This happens all the time. Particularly, but not exclusively, if you have flashed a new ROM.
The SGSII's battery fuel gauge is designed to re-calibrate itself automatically.
That is why Battery Calibration app's are a waste of time for the SGSII... they don't work. Simple as that!
The Best Way to Calibrate our S2 Battery ! No root needed, Simple, Accurate
