Help Phone turns off on it's own
BAMBAM86
So my HTC Vivid has powered down like 6 or 7 times on it's own today. Every time I turn it back on, it's working fine, but just continues to turn off on it's own! Today has been the most times it's turned off on it's own. I have Ice Cream sandwich. Anyone else having this problem? If so, any solutions? Thanks!
Mine has been doing the same thing for a while now. AT&T said it was an app so that was deleted and a factory reset was done on my own. The phone was still doing the same so I took it back to AT&T. The same tech then said he had to do the factory reset in store. He came back telling me to wait a few days before I add any new apps then add an app once a day to see what is causing the shut down.
Surprise, surprise...I have added no new apps. The factory reset done by AT&T was yesterday at 2 pm and the phone turned off about 4 hours later....Let's see what they say today.
Have you had any luck?
You clearly have a faulty Vivid. I would take it back and insist on a replacement phone, if it is still under warranty.
Hi,
Mine was turning off atleast once everyday.
Swapped the battery and 4th day running without a reset.
It might worth a try before declaring the phone faulty.
