Hey guys. I have a couple of battery/charging questions.
First being, is it normal for your phone to turn off then back on while charging to a computer? While charging my phone (which btw I squeezed almost TWO full days believe it or not
) via computer, at least my work one, my phone will shut off then turn on by itself and this cycles a few times as well. Doesn't matter if I start charging while on or off it will then either shut off or turn on pending on how it started charging and continue to do so until I'm charged to a specific %.
Is this normal? I haven't tried charging to my home pc yet but I would imagine it's the same right?
Next question is with the power saver setting, when the power saver goes into effect on the phone and you turn the phone back on after fully charging, is their a way for it to go back to normal settings? Meaning do you have to manually change things the way they were before the power saver went into effect? I sometimes just go into the power saver and turn it off then back on to get things back to normal after fully charging. Is there an easier way?
Seems kinda weird to have a setting go into effect and then not have it go back to normal when it's not required....
) via computer, at least my work one, my phone will shut off then turn on by itself and this cycles a few times as well. Doesn't matter if I start charging while on or off it will then either shut off or turn on pending on how it started charging and continue to do so until I'm charged to a specific %.Is this normal? I haven't tried charging to my home pc yet but I would imagine it's the same right?
