wrigglesworth
Member
Hi,
I rooted my phone a couple of months ago, just so that I could use the Link2sd app and get a reasonable number of apps onto it. I still use the standard ROM.
I've got S off, and hboot is 0.93.0001..
Today I turned the phone off. When I turned it back on it had apparently reset itself and gone back to it's factory state, asking me what carrier I use and what language I want the phone to use, etc! This is annoying enough, because I hadn't backed up, so all apps will need reinstalling. Well, not so bad in a way, because it gives me a chance to think what apps I use and are worth reinstalling. But when I start installing apps I immediately get the "phone-storage-space-is-getting-low" warning for the first app. It seems to me like all the stuff that was occupying the phone memory before it reset itself is still in there somewhere, leaving very little space for anything else, but is somehow inaccessible.
I guess I could just manually reset it, which would I suppose clear everything out, by using the "wipe data/factory reset" option or something. But if the stuff is still in there somewhere can I get it back without reinstalling?
