pacedrum69
After trying out ROM manager....my phone WILL NOT boot into recovery mode..... What do I do?? PLEASE HELP
I have no Idea how to do that....Im a total noob.... how would I do that?? When I press Vol Up+Power On...it just gets stuck on the boot screen ) skateboard guys)...Relax, have you tried re-flashing amon's recovery image? Have you tried re-flashing the clockwork mod recovery image?
Do not use clockwork recovery unless you want a nice looking brick for a phone!!!!!
Use ra its the only stable recovery we eris users have, i speak from experience clockwork recovery will give you a nice looking brick after a while of using.
Do you mean "throw it in the trash brick" (a true brick), or it just hoses up all the flash partitions so that you need to re-perform the root-ROM install and Amon_RA recovery install?
Just curious - wondering if you are being literal or lyrical.
eu1
Yea I meant an actual brick, you can't restore any nand backups, can't flash any roms, can't even flash the root rom, my phone couldn't boot at all so I tried flashing the root rom it failed, when it tried to reboot it turned off and never booted again.
