Hello there mth133996!!
Did you get the firmware file for your particular carrier? Is that AT&T? Where did you get the stock rom? Are you rooted or stock?
When you used ODIN, did ODIN say "successful" at the end?
In other words, did you get any errors during install?
I'm sorry for all the questions, but it just helps with some more info![]()
:smokingsomb:One does not have to be a Sherlock to see, that guy is coming from (downgrading) from 4.3 to 4.1.1
Well, unfortunately, there is NO going back from 4.3 as of yet. No way, Jose!! And he probably also has a "Knox warranty void:1" on his screen.
Same happened to me today. Tomorrow, I am going to "fight" with bootloaders, because THAT is what preventing me rebooting into recovery.:smokingsomb:
That is exactly what happened. Is there any way from me to get it to work again?
I will be working on it tomorrow evening.One does not have to be a Sherlock to see, that guy is coming from (downgrading) from 4.3 to 4.1.1
I still haven't found a fix.. i've tried everything..
SOLUTION FOUND!!!!
Just un-zip, and install this 4.3param_tz.zip | by AngryManMLS for Galaxy Note 2 in ODIN 3.07
Finally, it worked for me!!!!
I just made an acct to say thanks and this works. i was freaking out cus i have straight talk so i have to buy phones full retail price. i am so thankful for this! Thank you soo much for sharing this and God bless you!SOLUTION FOUND!!!!
