sammyfire2001
Member
I've been installing 2.7 (first time with Rom) and it's been installing for a while. It seems to be stuck on "copying flashable ZIPs to /sdcard/MeanROM-ICS.
Is this normal?
Is this normal?
My pc says that I need to reformat the disk before I can use it? Could SD card have been messed up during the installation? I can't reflash the rom because I can't see the files on my SD cardCan you reflash the ROM? Make sure you're doing the appropriate wipe. Did you check the md5 checksum before flashing to make sure it wasnt a bad download?
When you hook the phone up to the computer can it see the missing files? (Mount USB storage in recovery)
EDIT:
I also moved your posts relating to the problem from the MEANROM thread to provide more information here.
My Internal cardIs it referring to your external or internal card?
