Root Phone won't boot, won't go into recovery.
My phone won't boot or boot into recovery.
I tried what it says to do here: http://androidforums.com/triumph-all-things-root/419789-fix-mobile-partition-fix-phone-wont-boot.html and it still won't work :confused:
what happen did you format you MOBILE Drive? did you erase your recovery ? that fix is for ppl who erased/formatted there MOBILE partition/drive it depends if you have a OLD triumph or NEW triumph because there's two different set of files that go into the MOBILE partition/drive
I flashed the newest CM7 (I did wipe and wipe caches. I was on the gingerbread ROM with the working HDMI.) Then it just stayed on the boot logo forever. So I followed that guide (I erased the file in the mobile drive and extracted the new one into it.) and it's doing the same thing, staying on the boot logo and recovery won't work either.
And my phone is from 08/11
Ok, replace the recovery.img with your choice of custom recovery, then boot in to recovery and wipe cache and it should boot. When you replaced the mobile partition it put back the stock recovery. If you ever run in to a problem like this, you should post a question in the ROM thread. There are a few people that have had this problem with the newest CM7. Apparently you have to format the cache after you install the ROM to get it to boot. So, for now I would try a new recovery and then use an older version of the ROM or restore a backup until it gets fixed. Hope this helps.
when going from ROM to ROM is best to do a FULL wipe and factory reset you would only have to wipe both caches if you updating the same ROM but even them is best to do a FULL wipe and factory reset to make sure . only wiping the caches will get you stuck on a BOOTLOOP ...ok the guide tells you to erase the whole IMAGE folder inside MOBILE inside IMAGE there is the 'recovery' file (the only file you should be messing on the MOBILE drive in the future dont mess with the other files inside here there needed to make the phone boot)NOW since all your IMAGE folder was erase and replaced with other files which most likely werent for your particular phone thats why now your still stuck on a BOOTLOOP ...i need to know couple things to help you better A.did you erase the whole 'IMAGE" folder inside the MOBILE drive ? B. Did you replace the whole "IMAGE" folder with the one from the guide? have you tried to boot into recovery mode with the button combination after replacing the files??? C. try to boot to recovery boot pressing the button combination see what happens D. do you know what download mode ?E. Can you boot into download mode ? (well since you did replace the files with the ones on the guide you can boot into download mode)F. when you boot into download mode is there words/text on the screen?
Thanks a lot, that worked :)
Thanks for your help
anybody can help me, i get the same problem with urfreaky, but the problem cause after root my tablet and i use room manager application and when i select fix permissions its scan all file in the internal storage and after all process complete the tablet reboot automatically and after that it wouldn't be boot and can't entering to recovery mode even i have press any combination key, it still won't boot. Can anybody help this problem
Not sure. This thread is for the Motorola Triumph, and you haven't said what tablet you have. You will probably get moved to another thread, but we would need to know what you have.
This My Android Tablet Specification :
Brand : Tabulet
Model : Beat Duos
Official web : Tabulet PC
UI/OS : Android 4.0 Ice Cream Sandwich
Flash Support : Yes
Processor/CPU : Dual-core Scorpio MX up to 1.5 Ghz (Made in USA)
GPU : Dual-core Mali 400 3D
Processor Memory (RAM) : 1 GB DDR3
ROM : 1 GB DDR3
Internal : 8 GB
I always always ALWAYS did a full wipe between ROMs with the MT and never had any issues. Only time I wouldn't is if you are flashing a new kernel or theme zip, then wipe cache/dalvik cache & you should be good...
@rcsrich : thanks for your response about my problem, I try to answer according your analyst. A. I didn't erase anything file or folder, i just did use rom manager application and i tab on to fix permission like i told before. B. I didn't replace anything image folder and i can't boot into recovery mode and i had to press any button combination in my phone, as information there was 4 button in my tablet 1. power 2. vol - 3. vol + 4. reset button, and i had to press any all combination button and it wasn't work. D. I don't know how to entering in download mode. That I can see when i press the power button only my android tablet logo
k4m1l- looks like a decent tablet, but I don't see your tablet manufacturer or model listed at all in any of the Phandroid forums.
I'd check other forums (Android Central, XDA) and see if it shows up anywhere else- I doubt we are going to be able to provide much help.
