Root Phone wont connect to desktop
After downloading and instaling the usb driver to root my phone my phone will not connect to my desktop no more so I can put anything on my sd card or move stuff from my sd card to my computer is there any way to fix this?
If the above suggestion doesn't work, we may need to look into your build prop file to make sure the usb prop didn't get messed up through the root process.
DS
