Help Phone won't initialize, stuck on "android" screen
sdjim2
My Optimus V won't initialize, it's stuck on the "Android" screen............?
Anyone have help? Thanks.. sdjim2 (san diego)
I have this problem as well... I tried a battery pull and when the phone starts it shows the LG symbol and then goes on to the android symbol with the glare moving on it from left to right. That glare keeps looping over and over. I can use ROMTools by mmmark111 and it lets me boot to recovery but i cant seem to do anything to get my phone back alive even from the menu. I can even use ROMTools to successfully flash the recovery but it doesnt help at all. What should I do?
I encountered the same problem today. Stuck on the Android screen. I removed the battery and the data card and I get the same problem. I tried to access the card on a computer but it wound not show up. The only way to shut it down is to pull the battery. Any suggestions?
More.. I just got to the opening screen. It had the wrong time and said 'low on space." I quickly tried to connect it to a computer and it went back to the Android screen loop...Oh well.
