oOMavrikOo
Android Expert
I'm running the latest aospCMod with firats at 100 18. I use an app called Cache Cleaner NG because it cleans the internal memoery and the SD memory. I've Bennett using it for about 6 months with no issues. I was using the app and for some reason it was taking way too long to clean the cache. I pressed the home button because back wouldn't work at the time. Afterwards my phone was very laggy. I noticed that the cache cleaner was still running in the background also. I tried wiping the data on the cache cleaner but kept getting force closes on Titanium Backup. So I booted into recovery and wiped cached and dalvik cache. The phone rebooted fine, but not it will not read the SD card at all. When I check storage settings it says unavailable. I've tried taking the card out and pitting it back in several times with many reboots, nothing's working. I've read online that a possible fix is to do a factory reset on the phone. Is this the only option?
Forgive the lack of paragraphs. I'm on the phone typing this and am in a hurry and can't see where to break the lines. Thanks for album help guys.
