phone wont reboot after siyah kernel install
  • Start date Start date
A
Android Question
Guest
how to get my phone to boot up. after I installed siyah kernel 1.9 on s3 using odin after installing it never rebooted and is stuck on yin yan screen but I can get back into download mode what do I do to fix the problem
Maybe try taking the battery out and connect to charger wait for it to boot and then insert the battery again. This happened to work on most phones I've tried it on
You might consider signing-up here at AF and post something in your device's all-things-root thread.
Hopefully your kernel version is compatible with the ROM you have installed (perhaps restoring your latest Nandroid backup or flashing the previous kernel you had installed would fix things? :dontknow:).
Best of luck!
