so my desire has problems remembering defaults. im running cyanogen 7 on it. whenever i long click search to bring up the voice command, the dialogue box comes up saying "Complete action using" and then lists "messaging, voice search, widget locker"
when a call i am on ends, the "complete action using" box comes up and lists off the 2 different dialers i have.
if i select a default and tick the box saying to "use by default for this action" it seems to forget that whenever the phone is shut off, or after long enough time
also every few days my gmail stops syncing and when i check the sync settings, the gmail box is unticked.
anyways to fix this?
