Root Phone won't shutdown.. wth?
Tokenpoke
Android Expert
My phone won't shutdown...
It sits at the shutdown screen for 1hr or more....
Running a combo of admiral beast and Dwayne's theme thingie ...
Any ideas?
Do a battery pull and see if that helps. Not sure if a dalvik wipe would do any good but you can try that also. If it keeps on doing the same then just remove the theme. Hope it works
.... oops....
I accidentally deleted the odex for the shutdown app..
Restored my admiral backup and reflashed theme. All is good on the hippie front.
