brownhornet
Ok so after applying the update my awake and uptime are identical. I'm trying to see whats the easiest way to find the source of it? Im guessing its an app that I was using on 2.1 that isnt working right with 2.2.
Start here, follow in that order:
http://androidforums.com/htc-evo-4g...r-battery-life-after-froyo-2.html#post1276272
Then, if trouble persists, factory reset and then repeat the Network cdma->gsm->CDMA auto (PRL) + update PRL step -- don't skip that advice, srsly.
