Help Phone won't sleep
TravisG
Member
For some odd reason my phone will not "sleep". The screen just stays on. The only way I can get it to sleep and the screen to lock is to push the power buton on top of the phone. I have the screen set to time out at 1 minute. I have searched and read but no real answers for this phone. Any help?
Might have a rouge app.
Install spare parts from the market. Click Battery history. See what Running % is (sounds like it'll be 100% for you, which is bad).
Click on other usage and choose partial wake usage. Anything accumulating significant time there is bad.
Downloaded spare parts. Running 97.1% and screen on 96.5%.
Partial wake usage: Android System 21m 14s
UID 1001 3m 8s
UID 10002 2M 20S
Motorola services 1m 50s
Nothing looked way out of whack to me.
UID 1001 3m 8s
UID 10002 2M 20S
Not sure the partial wake is a problem, but the running/screen are way out of whack.
Sounds like you found your answer with F+
Running should be maybe 10-20% more than screen on time, at least it is for me.
If your screen on is at 15%, I'd expect running to be around 25-30%.
I'm having this issue too, intermittently. How do you do a forced close F+?
I'm not sure if this is the right way or the best way maybe someone with more experience will chime in. I went to setting>>>applications>>>manage applications>>>running>>>f+>>>force stop.
Hope this helps
