I upraded my Huawei U8800-51 from Build u8800v100r001usac07b635 (Android 2.2.2) to U8800V100R001C00B526G001 (Android 2.3.5).
My wifi didn't work, so I downgraded to Android 2.2.1 (Build U8800_V100R001C17B162CUSTC17D001).
The upgraded said it had completed successfully and was going to restart.
It turned off and didn't turn back on. I waited about 15-20 minutes and tried to turn the phone on, with no luck. I took the battery out, plugged it into the charger and it vibrated, stuck the batter in...no luck.
So, holding the volume up and down keys and the power button to re-initiate the upgrade doesn't work, nor does holding the volume down button and power button.
All it responds to is pressing the power button, which makes the phone vibrate...or plugging it in without the battery, which makes the phone vibrate. The charging light doesn't come on, nor does it respond any other way.
Does anyone have any ideas on how I can get it to turn on?
