Help Phone won't turn on! Please Help!
Viper1117
My phone worked fine this morning but when I got to work the screen won't turn on. The soft keys will light up but no haptic feedback. I have tried plugging it in, pulling the battery, and a hard-reset still nothing. I got the phone on the 11th so I am past the 30 warranty. Any suggestions????
Hi - did you ever solve this problem? I'm experiencing something similar, although it might have been caused by a brightness widget that I downloaded...
yep, there is a problem with one of the back light widgets. there is a couple of post about it on XDA so you might want to check over there.
