rvarn1
Order of things that happened:
Got 4th replacement phone
activated
swapped out CWM recovery (5.x.x.)
flashed cm7 b.08
flashed gapps, and OC kernal
booted into a clean install. I wanted my old apps back (dang angry birds!)
Restore nandroid, use for 1 week
Notice wonky battery calibration, and some rarely used apps acting wonky
boot into CWM, wipe cache, dalvik cache, and battery cache
now, my phone won't do anything besides sit at motorola logo. What can I do to fix my error, if it is indeed an error? I called VM to just get a new phone, but they don't have any in stock... so am I screwed for a week until I can get a new one?
Thanks
PS if there's already a forum about this, I didn't see it. Merry christmas
activated
flashed cm7 b.08
Thanks
I should add that I've tried recovery mode, and just booting the OS. The only thing it does is sit at the motorola logo, regardless of what I do. If I pull the battery and plug it in, it vibrates, and then shows a full battery charging icon thingy.. then the screen blacks out and shows a dead battery icon. If I unplug it and then try to boot it it shows the motorola logo; the only thing different is if I try download mode for changing the recovery...
feeling noobie now :/
id cry lol
i was saving the $40 dollars to put torward chrismas gifts, so its all good
) if fixing the recovery will help. now just a general knowledge question: why would my phone bootloop if I formatted cache
