Photo ID
Select People and then the person you would like to add a picture for. Then in the top grey bar press the persons name and it will bring up a new screen. You should see a Head Silouette with and Arrow drop down on the upper lest hand corner, press that and then you can select a contact photo. Or if you open Photos and then long press on a picture it will give you a bunch of choices. select Set as.. And then Contact Icon
Thanks a million!
