Help photo sphere on s3 help
Dalvik is in custom recovery (CMM, TWRP etc) do you have one of them installed?
Ill try using that guide when i get home. Ive been meaning to get photosphere again :thumbup:
Edit that guide is for touchwiz roms and im not on touchwiz.
Did you do the "fix permissions" part?
just installing clocwmod recovery and usimg rom manager to fix permissions (doing as i type) but there wss no option for that in recovery, im wondering if the file is good?
thanks
Sorry thats me home. Yeah im pretty sure it was autoroot i used and it put CWM on my phone. Youre gona need that. As for Rom Manager, i dont know why but people dont recommend it for the s3
hmm i dont seem able to geg cmrec mod to flash/install, either via cf or rom manager ive done it before with these exect files, odin 3.04 dont think that need to be 3.07, v odd maybe last build did something to stop it?
Not sure man. I hate computers so after rooting quite a long time ago, ive done everything on the phone without a pc.
Run the Root Checker app :thumbup:
Isnt it PIT? wait till i google an image of odin coz i cant remember lol......
EDIT scrap that lol. Its PDA :)
Yeah try it man but i doubt its that. Is the root file definately for JB and not ICS? (Not sure if theres a difference tbh)
Is Usb Debugging checked in developer options?
