Hi,
love my dx but i'm having problems when i try to upload multiple pix to picasa.. no one else seems to be having this problem.
hopefully i can explain intelligently
i've searched for everything i can think of on the subject.
when i upload pix using the share>>picasa feature, it will upload some and then tell me it's waiting 1 minute to retry. when it retrys it picks up where it left off and uploads a little bit more then stops again.
for example.
try 1: upload 32%
try 2: starts @ 32% & goes to 62%
try 3: starts @ 62% & goes to 94%
try 4: finishes...
this is really annoying when you're trying to upload 50 pix...
however, if i upload a single picture and select upload to "web album" i can upload that pic on the 1st try. unfortunately, i don't get that option when uploading mulitple pix...
if this isn't fixable, is there another app i can use?
i've searched for everything i can think of on the subject.when i upload pix using the share>>picasa feature, it will upload some and then tell me it's waiting 1 minute to retry. when it retrys it picks up where it left off and uploads a little bit more then stops again.
for example.
try 1: upload 32%
try 4: finishes...
