Help Picture resolution/size?
sar050680
Can anyone tell me is there a standard size for a picture when setting it as your wallpaper please?
I have a couple of pics that I want to try but the pic is to big when I set it to wallpaper! I have tried resizing but with little joy.
TIA, Paul.:(
TIA, Paul.:(
Yes the default size for wallpaper is 960x800 since the paper scrolls in the background.
If you want to put custom wallpaper on the Desire, you have two options. First is to get any image and transfer it to the memory card. Then view the image and hit the Menu button to set it as Wallpaper. You can select a section of the image, resize the section you want by dragging the crop box, and save it. It's quite easy really.
Or you can get an app that will apply images as wallpaper for you.
Any recommendations on how big in kb I should be aiming to make the wallpaper? Am playing around with a couple of images for wallpapers but wondering how much I should reduce their quality.
