Devendra95
When ever I restart my Samsung admire (2.3.6 stock), I noticed some pics just disappeared. They are no longer in the gallery. And this happens every time. It is really frustrating. Please help
could this be the SD card's fault?Had this happen with a friends G1 awhile back-first off un-mount and mount the sd card. Some may reappear and some may not. Next sign up for an account for Dropbox(Google Play Store has a link)
Download the app and set it to upload new pics in the settings of the app.
Now with my friends G1 it would not show all the pics on the device itself but everything would be saved to Dropbox safe to view on the phone or a computer:thumbup:
nopeIt could be-sometimes just unmounting the sd and mounting it again takes care of it. Do you have the option of trying another sd card![]()
but right now i have a 2GB and i will upgrade to a larger size in the near future.Thanks for your help. I used an app called "sandisk memory manager" and set up a box account and I backed up everything on my phone.Ok-setting up dropbox at least will ensure you don't lose anything in the meantime![]()
I'll only buy Kingston or sandisk 4gbwarning with the sdcard's
make sure u buy a legit sdcard, there are fake sdcards floating around.
they report a certain memory space but are not, buy from a trusted source, dont skip on the cost. i purchased a 30gb fake sdcard and had the same problem, apps/pictures disappeared due to goign over the limit on the card, was 4gb but reported 30gb.
its an sdcard error, backup ur files and format ur sdcard.
cheers.
