I'm using Virtuous 3.0 with Smooth Super Circle Battery + Smooth Sense Icons mod and a PIN lock pattern. After unlocking, the buttons on the PIN screen are a horrible white color instead of transparent as they were with the stock rom. I then renamed the HTC lock screen apk so it uses the default lock screen but that did not fix the problem.
I looked at different themes/mods but they all seem to be either vanilla rotary or are bundled with some theme package which I don't want. I also read about widget locker and that it might drain battery because you're running another home app. Where can I get a good lock screen? Perhaps something like this? (http://androidforums.com/virtuous/187761-themes-customization.html#post1881931)
