W wbiz Lurker Nov 21, 2013 #1 Hi, I own Samsung Galaxy S Advance I9070, which has GingerBread OS. Is PIN-Lock for screen completely foolproof or safe ??
El Presidente Beware The Milky Pirate! VIP Member Nov 21, 2013 #2 No security method is absolutely 100% fool proof or safe, but if you make the PIN long enough, it will deter most from trying to access your device.
W wbiz Lurker Nov 26, 2013 #3 Thank you for the info. But PIN is only of 4 Numeric characters. How to go for long alpha-numeric passwrods(PINs).
El Presidente Beware The Milky Pirate! VIP Member Nov 26, 2013 #4 All of my devices have an option to set a password as well as a pin. Take a look in Settings, Security (although it might be elsewhere on GB). You should be able to make your PIN longer than 4 digits too?
