I'm sure these have been regurgitated to death, but I really like the clean no-fuss way the details are presented over in the Pixel Help Center:
https://support.google.com/pixelphone/answer/7158570
Operating system Android 11
Display
Characteristics
- Full-screen 6.0-inch (151 mm) display with transmissive hole
- 19.5:9 aspect ratio
- FHD+ (1080 x 2340) Flexible OLED at 432 ppi
- Always-on display
- Now Playing
- Touchscreen
- Smooth Display (up to 90 Hz1)
Dimensions and Weight2
- 1,000,000:1 contrast ratio
- HDR support
- Full 24-bit depth for 16 million colors
Dimensions
Weight
- 5.7 height x 2.8 width x 0.3 depth (inches)
- 144.7 height x 70.4 width x 8.0 depth (mm)
Battery
- 151 g
Memory and Storage
- Minimum 4000 mAh
- Typical 4080 mAh3
Memory
Storage
- 8 GB LPDDR4x RAM
Processors
- 128 GB storage4
Rear Camera 12.2 MP dual-pixel
- Qualcomm®5 Snapdragon™ 765G
- 2.4 GHz + 2.2 GHz + 1.8 GHz, 64-bit Octa-Core
- Adreno 620
- TitanTM M Security Module
16 MP ultrawide
- 1.4 μm pixel width
- Autofocus with dual pixel phase detection
- Optical + electronic image stabilization
- ƒ/1.7 aperture
- 77° field of view
Front Camera
- 1.0 μm pixel width
- ƒ/2.2 aperture
- 107° field of view
Video
- 8 MP
- 1.12 μm pixel width
- ƒ/2.0 aperture
- Fixed focus
- 83° field of view
Rear Camera
Front Camera
- 1080p @ 30 FPS, 60 FPS, 120 FPS, 240 FPS
- 4K @ 30 FPS, 60 FPS
Sensors
- 1080p @ 30 FPS
Charging
- Proximity/Ambient light sensor
- Accelerometer/Gyrometer
- Magnetometer
- Pixel Imprint™ – back-mounted fingerprint sensor for fast unlocking
- Barometer
- Spectral and flicker sensor
Buttons and Ports
- USB-C®6 18W adapter with USB-PD 2.0
- 18W fast charging7
- Qi-compatible wireless charging8
- Reverse wireless charging9
SIMs
- USB Type-C® 3.1 Gen 1
- Power button
- Volume controls
Media & Audio
- Single Nano SIM
- eSIM
Wireless and Location
- Stereo speakers
- 3 microphones
- Noise suppression
[US]
- Wi-Fi 2.4 GHz + 5 GHz 802.11a/b/g/n/ac 2x2 MIMO
- Bluetooth®10 v5.0 + LE, A2DP (HD codecs: AptX, AptX HD, LDAC)
- NFC
- Google Cast
[ROW]
- GPS, GLONASS, Galileo, QZSS
Network11
- GPS, GLONASS, Galileo, QZSS, BeiDou
5G Sub-613
- LTE: Up to 4CC (12 layers) DL & 2CC UL12
5G mmWave [US only]13
- TDD: Up to 1CC x 100 MHz 4x4 MIMO DL & 1CC x 100 MHz UL
- FDD: Up to 1CC x 20 MHz 4x4 MIMO DL & 1CC x 20 MHz UL12
[US / FI] Model GD1YQ
- TDD: Up to 4CC x 100 MHz 2x2 MIMO DL & 1CC x 100 MHz 2x2 MIMO UL12
[UK, EU, CA, AU, TW, SG] Model GTT9Q
- GSM/EDGE: Quad-band (850, 900, 1800, 1900 MHz)
- UMTS/HSPA+/HSDPA: Bands 1,2,4,5,6,8,19
- CDMA EVDO Rev A: BC0/BC1/BC10
- LTE: Bands B1/2/3/4/5/7/8/12/13/14/17/18/19/20/25/26/28/29/30/
32/38/39/40/41/42/46/48/66/71- 5G Sub-6: Bands n1/2/3/5/7/8/12/28/41/66/71/77/78
- 5G mmWave: Bands n260/n261
- eSIM
[JP] Model G5NZ6
/32/38/39/40/41/42/46/48/66/71- 5G Sub-6: Bands n1/2/3/5/7/8/12/28/41/66/71/77/78
- eSIM
Colors
- eSIM
- FeliCa
In box US, CA, UK, IE, TW, JP, DE
- Just Black
- Sorta Sage
FR, AU
- 18W USB-C® power adapter
- 1 m USB-C to USB-C cable (USB 2.0)
- Quick Start Guide
- Quick Switch Adapter
- SIM tool
Hearing Aid Compatibility
- Quick Start Guide
- SIM tool
- Google Pixel USB-C™ earbuds
Security and OS Updates
- M4/T3 HAC Rating
- Google’s devices meet the hearing aid compatibility (HAC) requirements set by the FCC. See g.co/pixel/hac
Materials
- Minimum 3 years of OS and security updates14
AR/VR
- 100% recycled aluminum enclosure15
- Corning® Gorilla® Glass 6 cover glass
- IP68 water and dust resistance16
Warranty US, CA, JP, TW
- AR Core
UK, DE, FR, IE, AU
- 1 year
- 2 years
