Help Play = FAIL
alboid
I had my play for about 2 weeks now and it's great but as of last night my phone keeps unmounting the sd card. So I mount the sd card and in 5 minutes I get a notification to mount the sd card again. HELP! P.S. When it isn't mounted I get take pics or videos and this is very annoying!
Make sure the back lid is on good because there is a microswitch in the back of the phone. If the microswitch isn't engaged, you will get symptoms like you described.
Also I tried to hot swap the microSD, with the phone on, and had issues with it reading the new card until I rebooted the phone.
Why say it is a FAIL if you just don't know how to use it? You could have just asked. May people have this problem and it is due to the back cover not being on proper. They are too scared to put the pressure needed to get it on all the way.
Welcome to the Forum. Enjoy your stay.
