Root Play Store issues
Last Saturday i was going from tagged rom to Sleipnir 4.0 to give it a go and it was a bad experience for my phone. All in all I ended up bricking,so I get it unbricked re rooted/cwm and went backed to tagged rom. Everything seems to be fine so far but I'm having problems downloading apps from play store. I get a 492 Error code. So I looked it up and tryed all the things they said to do. I did the clear data from play store and Google frame work trick and all it did was go from a 492 error to a 927 error. I'm just wondering if anyone has delt with this and knows a remedy to fix it.thanks
Did you verify your md5 before flashing your ROM? Have you tried uninstalling Play Store updates? Did you wipe cache and dalvik-cache? Have you tried reflashing?
Dunno how anyone would end up bricking flashing one of these roms unless you did something really dumb. You probably haven't been reading the instructions well enough.
I highly doubt it was bricked, it probably just didn't boot into the ROM and instead of booting into recovery he did a full reset.
That is what happened and I've never had a problem switching roms and trying something different hence not backing up. I'm just assuming it was a bad download from my side seeing I downloaded off 3g. And no snorge I read perfectly well, I'm not that guy that asks questions that's been solved already so I don't appreciate you jumping to conclusions about people.
I just gave up and started from from stock ROM in the unbrick guide and just rooted for the mild jump in the CPU. Everything is working just fine now.
I had the same issue. I was bugging out. Is my wife's phone. I just let it sit for a while and rebooted and it's all good. I literally had the same issue. And literally did the same fix as you. I thought it didn't work but its worked. Try again. Give it some time to settle . then reboot
Yes it was pretty annoying I'm glad it finely fixed itself because I was about to throw this phone in the fire place.
I ran into this a few minutes ago, I can also confirm, for what it's worth, that waiting a few minutes and rebooting fixes it right up.
