When you connect to WiFi you need to check the box below the password visible box.
Can you please be a little more explicit.
I just bought ASProxy for $5 only to discover that it requires the device to be rooted
Is that the case with the other app too?
Is there no way to use an authentication-based proxy without rooting?
No way to do it without root.
This is just sad. Rooting will void my warranty (I am in India), and at this point I just want to get things to work.
I also have a no-proxy connection where I have to enter my user id and password in the browser and then I can use any application -- which usually detects the presence of this connection. While this approach works on computers, it does not work for me on Android.
