Help Play store not downloading for me
Kcsuper
Just in the last maybe 2 days, I get an error while trying to download anything from the market. The searches are fine and I even erased my data and re-entered it to no avail. Anyone know why this is happening?
I had the same problem after restoring a backup... I just restored the one before the one causing the issues, and all it's well... might i suggest a fresh install?
I had a similar problem, I wiped the data for the store, market and then I uninstalled it and then I have a flash zip file for cwm that you flash and then after you resart it will update and then everything should be fine. The file is home on my computer so I cannot send it to you right now.
if you still need this you just put on sd and flash through cwm like any theme or mod. just wipe data for market first then uninstall then flash this then reboot and when you open market it will update and all should be good.
