Help Play store will not load
smitty543
Suddenly Google Play Store will not load updates to 'My Apps'. Get message "Error 927".
Help!
Stock M8 with Android 5.0.2; Sense 6.0; Software 4.25.651.14
You may have to perform a factory reset,And I know its a lot of work.But it will and does fix issues like you have.
Be sure to backup your data first.
Isn't there a way without a factory reset. It is my wife's phone and she would be quite upset to loos her data!
This why you do a backup on your computer,This works good: http://www.android-manager.org/mobilego
I don't know of anyway to fix it,I've ran into this issue before and the only way I could fix it,Was with a factory reset.
I even tried other Play Store version off the web and never got it fixed until I did a factory reset.
Is there a way to back up a phone to a MAC. I do not have a Windows computer, and I do not want to root her phone to make a nandroid.
Reading the site for Mobilego, appears that it is only for WINDOWS computers. I only have Apple computers - are there similar programs for use with Apple computers? Thanks!
Yes, We have Apple computers and Android phones!
Hi
Have you tried to connect to another internet?
I mean, you may try to use different Wifi or use mobile data to do the update.
Sometime, it works.
