Help PlayerPro VS. SD CARD
Hey guys.
So, I love PlayerPro. Its been great since I got it. But, for some reason, all of a sudden, it wont read my music from my sd card. I checked on Astro and its all there, so why isnt PlayerPro showing it anymore? I can get my pics from my SD card. Do I need to make a new folder and transfer music? Or maybe if I plug my data cable to my phone and my computer, it will fix itself? What's going on?
Please help. Thanks.
Hey guys.
idk about the app so i did a little googling lol, seems a bunch of people are having the same issue while a bunch of others are not
you can try opening it and renavigating it to the folder where your music is stored, then restart the phone and see if itll play
it may just be an issue with the player itself, you may wanna just go with a different player till an update come out or something, if u use a different player, or even the stock one and it finds and plays your music with no problem then youll know it was deff. the player causing the troubles
So, I downloaded doubletwist, and it wont show the music in my folder either, and neither will the stock android player. It was working fine yesterday, which is why I'm so confused.
maybe someway somehow it got messed up lol, if you were to hook your phone up to the usb and take the songs off, you can see if the pc can play them
or if you have the songs on your pc, you can try re putting them on the phone and overwriting or deleting the non working ones
usually i create a folder called music on the sd card first, then move all the music to it
You can try to backup the SD card and then format it and put everything back on. I have had a SD card get corrupted before, and that fixed it for me. Just a thought.
what BSydz said is what i seen most people say fixed there problem so it may be the road to take, i was just hoping and seeing if there was a way around doing that lol
