'/'@ johnstone its saying removing loading 't' from member names
i have a apk file that says, "Adobe Flash for armV6 processors"
I haven't tried it yet, please suggest me how i can test if its working.
Well play some flash in a webrowser....
soon as i get my galaxy y,
I have to go now.
keep the pda.tar uploaded.
good luck
I have to go now.
good luck
http://dl.dropbox.com/u/53138813/PDA-2.3.6-GalaxyY.zip
here is the link
may you help us to create custom rom, thanksCode:http://dl.dropbox.com/u/53138813/PDA-2.3.6-GalaxyY.zip![]()
check this at post 90 if it is what you wantHey everyone
The link of pda zip u gave me is of which pda?
The one u use while updating ur firmware or the one generated from terminal emulator
I need pda tar from terminal emulator
what is the alpha version?we have an alpha version of CWMbut i haven't tried it,,
A pre beta version or you can say a testing version with many loop holes which can solved.
hey i have some ROMS which i have modified and is working fine on galaxy y and is tested too.
we are currently working on cyanogen and recovery for trail of recovery you can see this and the rom is also available on that website.
www(.)romfory(.)blogspot(.)com
check it out do leave a comment.
Sure!!!!!
Gimme the link
So u all got the CWM finally!!!!!!!
