Yes and no. I'm using blackberry cable, is that the problem?Looks like your screenshot did not come through. I have rooted mine and 2 other fascinates with no issues. Are you sure the drivers are installed and you are using the factory USB cable?
I'm trying to root and followed each step but failed. Why and what am I missing? Very frustrated, there must be something that we are not being told. If all the instructions are there than why am i getting this on the prompt?????
I bet it is, I have seen numerous posts where for whatever reason the factory cable must be used.
try this first:
[ HOW TO ] ADB AND WHY I LOVE ADB commands <3
Then try to use/get a SF designated cable
Now things are getting complicated.![]()
