Hi guys,
While in Clockwork Mod recovery I attempted to partition my sd card (yes my heart sunk when i saw the don't use Rom Manager to partition your sd card sticky at the top).
I set the phone to partition the sd card ( this was the second time I had set a partition as initially it was a 2 gb partition - I thought repartitioning it to 1 gb would wipe the firstone and I'd have a 1 gb partition instead) The partitioning seemed to work ok so I went to reboot it using the optical tracker - I am not sure but i think the selector moved down as i hit enter. It started to boot but has since hung at the white HTC screen. Can anything be done to get my phone working again? Have tried holding down most of the keys / buttons in varying orders but it has not reponded
I am a noobie and i went through the s-off, rooting process and installing miui custom rom and was really happy with myself until I did this. Any help would be really really appreciated.
Many thanks, Paul
Many thanks, Paul
