Root Please help - bit of detective work needed
Grrrr Ti Backup keeps reporting it can't acquire root priveleges :(
Miui ROMs, like all custom ROMs, will be pre-rooted. Try the "problems" button in Ti.
Otherwise, can you start up the superuser app? The go into settings and check the "automaticl response" is set to "prompt" (it should be by default, but you never know).
Omg small world - I'm in Hatfield about 2 miles away from Axholme and Polypipe is on wheatley hall road - which is close to the school I work at.
OK at the bottom of the Ti page it states:
System ROM: 262MB (119Mb free)
Internal: 154MB (53.5 MB free)
SD Card: 14.8GB (14.7 GB free)
Then 3 white boxes with Ceck for Problems, Updates and Pro Version in it
The sd card settings box reports in a2sd+ that there is the same amount of space free after having installed GOSMS Pro (5.8mb), Swiftkey (3mb) and Google Maps 6.1mb :(
Ok ran the a2sd reinstall on terminal emulator as instructed in your post Hadron :) As for TI back up I uninstalled n reinstalled and it worked :)
Yay I now have fourth entry - SD Card (A2SD): 1 gb
according to Ti Backup :)
Will move over the Dalvik Cache now :)
Will i need to uninstall and reinstall my existing apps for them to shift into the a2sd partition?
Aha I think it did it automatically - clever - 140 mb free now on internal storage from 53.5mb free.
903Mb left on the a2sd card partition.
