Help please help, cant answer phone calls!!
MDbandit
for some reason, when my phones rings, there is no damn answer button!!
only an end button
what would cause my answer button to be missing?
i havent installed any other phone answering/calling related apps
Have you tried a battery pull? If so how about a factory reset to see if that cured the problem? I know those are extreme but it sounds like you might have to do something like that.
Before doing a factory reset, we need more info, take a picture of your screen and post it, also have you done all the OTA updates ??
only an end button
is there a way to do ti with the 3vo 3d? otherwise i have to find a camera
and no, i havent done any OTA updates ,because I wanted to wait to make sure that wouldnt prevent me from getting root in the future........
Yes you will need a camera, IMO I would not worry about the update, but in the meantime take the picture first and let us see what your talking about
I had the same problem. just installed the latest updates and it fixed the issue.
One thing I am looking for is the guy at the store had a feature set on his 3d that when someone called two little androids would appear, one green one red and he would just drag the icon to the circle to answer the call. pretty cool. anyone know how to set that up?
ps... i did not want to do the update for the same reason ;-)
ah ok
well yeh i havent updated yet
waiting for them to say if the root exploit will work for the current OTA's
i tried resetting my phone, and it still ended up happenining again
when i first reset my phone, when people called, it had the 2 lil androids things as well
but then when i reinstalled some apps, it reverted back to the old way of the phone answering
i guess i need to do the OTA update
but i need root!
IMO you can still do the updates, but I would do it now before they install another update
ah ok
but i need root!
