cyaiphone Android Enthusiast Apr 7, 2011 #1 i recieved this Data call failure error code 67. registration failure your pcs vision username and or password may be incorrect try again. wtf??? I haven't changed anything.
TheEngineer Android Enthusiast Apr 7, 2011 #3 tube517 said: Update your PRL Settings>System Updates>Update PRL Click to expand... Almost. You need to update Data Profile. Or you are trying to use the Hotspot and do not have the plan for it.
tube517 Android Expert Apr 7, 2011 #4 It's been a long time since I had to do it. I think I updated both but I cannot remember. TheEngineer said: Almost. You need to update Data Profile. Or you are trying to use the Hotspot and do not have the plan for it. Click to expand...
