homeboy2k12
i am on CTmod 3.68, kenel 2.635. And can't conect to wifi. My wifi keeps scanning, and says conected and then desconected and kepps doing that.
Any help will be apreciated.
no it is not the battery. it is fullIt may also do that if your battery is real low.
i tried that already, it's seem like the problem is inthe phone or maybe the rom[=Lordvincent 90;4706879]Long press the name, select forget network, then select the name again and re-enter your password. If there is no password, unplug the router and plug it back in and try to connect again.
thanks man, this workedUnplug your router and modem for 60 secs then plug them back in, wait like 5 mins then try connecting to wifi again.
