Help Please help! How screwed is my phone?
So during a crazy party over the weekend, I managed to drop my moto droid into a mud puddle...twice. Yes I know, complete fail. It managed to keep working somehow, but after calling for a taxi, I noticed my airplane mode turned on and I missed their call. I turned it off, called back, and the phone worked normal all night. Now I wake up to hell, phone is at bootloader screen and saying stuff like battery is OK and connect data trasnfer cable. So I restart back into the hacked bootloader or whatever it is called, do a system restore of an old nandroid and it is back working. Only now the phone starts in airplane mode, and when I press it, it does nothing but make the option unpressable after being pressed once per start up. My wifi does still work, and everything else seems fine, but it did restart to the bootloader screen again after a day. I just plugged in the phone without doing another nandroid restore, and it went back to the airplane mode issue. So, how screwed am i? Physical problems or would a complete restore fix the issue?
Thanks so much for any feedback!
update - after further research, I am seeing under the phone information in settings, that my phone number is unknown and mobile network is disconnected and many other things are off if this helps. Thanks!
