OK I have tried to add my ringtones to my notifications but it wont let me I tred making folders on the sdcard and that doesnt work either does anybody know hoe to add them thanks Dennis
Create a folder named "Media" on your sd card. Inside that folder create a folder named "audio". Finally inside that folder you can create "ringtones" to put ringtones for your calls, and "notifications" for your text messages, email, im, etc. Should look like this:
Media>Audio>Notifications>Whatever the name of your notification ringtone is. The phones stock notification sounds are all .ogg format, but .wav worked for mine.
the "GuntextmessageAm" option is not standard, thats my own. Hope this helps
