Help PLEASE HELP! HTC Desire screen won't turn on after it goes on standby
helenfoz
Hi there
I dropped my phone this morning and now when it goes on standby the screen wont switch back on. Its still on and i can receive calls but the screen is black.
When I take the battery out and put it back in it comes on again but as soon as it goes on standby I am faced with the same blank screen problem.
I stupidly haven't got insurance and it is over a year old so wont be covered under manufacturer's warranty. Anyone any ideas how I might go about fixing it myself?
Thanks!
Helenfoz
I'd suggest trying a factory reset - make sure all of your data is backed up first.
It doesn't REALLY make sense that a FR would fix this particular problem, but obviously the screen works, so maybe just a start-from-scratch will help it work out whatever problem it has.
It depends on the damage. It may be a loose connection. Take it to a phone shop to repair.
Does the power button work at all?
When you put the battery in, does it come straight on without you pressing the power button?
If so, it sounds like the button is stuck in from the fall. You can't press it to bring the screen back as it's already stuck in the closed position.
Hiya
Thanks all for the responses
SiHa
the power button works when I press it after putting the battery in to turn the phone on and also works to turn the phone onto standby, its just turning it back off standby that doesnt work. Also when I make a call after the call has finished it goes on standby and won't come back on :-(
I'll try a factory reset tonight but not getting my hopes up mhotovec like you say it might not work.
If anyone else has any other ideas or has experienced the same problem let me know!
Its usually a couple of weeks with HTC, but if they will accept it, it is worth doing, however, cost - I have no idea. But the work will be covered by warranty.
Manufacturers warranty is 2 years on teh desire by the way, but that woldnt cover this.
Will let you know tonight after I have a go at the factory reset. Keep your fingers and toes crossed it works :-)
Oh and I dropped my phone in the bath about a week after getting it (just over year ago) and haven't had any problems until dropping it this morning, but I dont reckon the manufacturers warranty would cover it getting fixed as the water damage stickers in the phone are red.
I really should take more care with my phone shouldn't I!
Ah, that won't help.
Hope you get it sorted.
So done a restore of my desire and it still isnt working properly :-(
Have also noticed that if I leave the phone on charge for 30mins or more and press the standby button then it works. But then try it again immediately after it doesnt. It really is strange.
Have spoken to HTC who said they will pick it up for repair on Monday and then quote me how much it will cost to fix. If its too much they said they can send the phone back for a fee of around
By any chance do you have a different battery than you can try, or know someone with the same phone that you could borrow their battery for a few minutes? I'm just curious to see if it will wake up properly with a different battery.
It's been wet, it works again after being plugged in - MIGHT be a battery problem.
Ive just got the phone back from HTC and they said they wont fix it because of the water damage. It really sucks because I know its nothing to do with water damage as it happened over a year ago and had been working fine until I dropped it last week :-(
Ive tried another battery in it and that doesnt affect it. Still have the same problem.
Im thinking my only option now is to have a go at taking the phone apart myself to have a look and then if I cant figure it out myself Ill just have to sell it as broken :-(
Really gutted!
Thanks loads SiHa been hunting for a good guide this afternoon and this one looks good!
I have heard people have had similar issues with other HTC's where they mention it being something to do with the proximity sensor? Dunno if thats the same problem here though.
Yeah, I did wonder about the proximity sensor, but it seems unlikely to me as the screen only doesn't come on from asleep. The proximity sensor should only be active when you're making calls.
You could download a sensor test app from the market to see if the sensor is doing something iffy, maybe.
If course, if it is the sensor, it'll still need repairing.
Downloaded a couple of proximity sensor apps and it is working so it doesnt look like its that. Also tried an app that is supposed to wake the phone up on when you blow into the mike. It does wake it up as the keys light up but doesnt switch the screen on so I'm still stuck with the same problem.
Its so strange! Especially when I leave it on charge for at least 30mins and then the standby button will work!
Odd.
It sounds like maybe something screen-hardware related has been damaged, and it needs a higher voltage (such as it would get after a charge) to turn on the screen.
Is your phone SLCD or LED? You can check by getting a black or very dark screen to display and going into a darkened room. If you can see light bleed from the edges then it's SLCD
If it's SLCD, when the screen doesn't turn on, it could be just the backlight that is not coming on. Have a look at the screen ander a bright light whilst pressing the power button to see of you can see any vestige of an image coming up.
Its an LED screen :-(
Just hoping now that when I open it up I might be able to spot a loose connection of some sort or clean away dust and it will miraculously work!
If you have anymore ideas please let me know!
Thanks for trying to help :-)
Just hoping now that when I open it up I might be able to spot a loose connection of some sort ...
I think that's probably your only option now. If you are anywgere near Bradford, maybe take SUroot up on his offer of pointing you at a good shop?
I got my mate at work to take my fiance's hero to a shop he knows in bradford. They changed her digitiser. I can ask the name and address of the shop if you like?
Hi Suroot - missed your post before! Thanks to SiHa for pointing it out. That would be ace if you dont mind? Might get in touch with them. How much did it cost if you dont mind me asking?
